1 - 6 of 6 Posts
Hi all been away to long :). looking to replace front lower control arms, going to purchase from rock auto and been eyeballing the moogs, and the mevotech supremes(reviews say better than oem). I was going to go with moog but read reviews stating anything they make now starting with RK part number is made in China.
which is better? Also do these come with cam bolts? If not does anyone know the OEM Toyota part number for front lower control arm cam bolts
トヨタ Master
Since you've been a member since 2007, I am going to assume that your FJ is an early production. The entire set contains:
4 x 48190-60040
4 x 48409-60040
4 x 90119-14120
4 x 48198-60020
4 x 48452-60020
And can be found at purefjcruiser.com below.
This is the full diagram:
Most individual parts are also available at your local Toyota dealer.
Forum Beer Miester
Dang I had a complete set with lower cams that had grease zerks, I sent them back a few ago.
MOAB SUPERSTAR
Moog makes greaseable cambolts which are highly recommended in areas with salted roads. Moog balljoints are also what dealerships use to rebuild OE LCAs (Toyota balljoints are not sold separately). I personally would only use OE LCAs but have had good luck with the Moog cambolts.
1 - 6 of 6 Posts
