It depends on what year you have and/or what hack you have performed in order to be able to do this.I noticed today when stopping on slush covered roads that my abs came on even though I turned the vcs off. Is this normal? I thought ALL vehicle stabability control systems, including the abs system, were supposed to be off.
You will need to do the hack to disable it. You can get the same result by unpluging the harness at the master cylinder. Here is what I did but go to post #148 or you can read all 30 pages if you would like.It's a 07 with a manual. I've had it since new and have driven it every winter in new york and when I have the transfer case in the position where it turns the vsc off, the abs never came on until today. I sort of remember reading in the owners manual that the abs system shuts off when the vsc is off.
