1 - 11 of 11 Posts
i'm wanting to add another sub in the back of the fj and was wondering if i can splice into the wires that go to the other sub or do i have to run new ones back ?
You will need an amp and an ohm load meter. Put in fj cruiser speaker in ebay you will be amazed at the available options. One is a site vender I'm sure someone will add to my post. Its a great system two 10" and box with JL stuff.
________
Medical marijuana card
I'm looking at adding a second sub to this first one:
I'm using a JL Audio 700/5 amp to power the speakers and sub - can run a second sub in parallel pushing 350 watts or so total (to the subs)
Ideally you'd run RCA cables from your sub output on your head unit to get signal back to a new amp and subwoofer. The stock subwoofer's amp only has enough power for itself and really shouldn't be split. If you want more bass and want to save money, you can search for upgrading the stock amp and sub while keeping everything in the stock housing.
You'll really need an amp to power it most likely. What sub is it, and is it in a box already?
Same thing happened to me. My friend gave me a sub+amp. You won't be able to power the new sub with the stock amp.you would have to get a new amp to power the new sub and you need to run a new power and negative cable to it. If you have the fjammer head unit you will not be able to run RCA cables from it due to the fjammer not having any. So you have 2 options, get new head unit or you will have to get an adapter that ties into the original wires that go to the factory sub, it costs about $20 to do that and I'll give you the name of the adaptor if you need it
The head unit doesn't power the sub directly, it just sends the signal to the sub's amp inside of the subwoofer enclosure.
1 - 11 of 11 Posts
