1 - 11 of 11 Posts
So the castle nut on my knuckle by the UCA disintegrated as I was removing it. Is there a special socket that could remove it? I’m basically stock in my driveway so it has to be a driveway solution. Thanks!
Liquid Fluid Automotive tire Gas Water
Plenty of penetrating oil over several day. Try Gearwrench Bolt Biter extraction sockets. They work well.
Reactions: FJJF
2013 Trail Teams <>< <>< <*((^(((><
And a torch may help but be careful of the oil you put on the bolt.
If you are taking it apart to replace the ball joint, then that means both the nut and stud are expendable: angle grinder with a cutter wheel to zip them both off flush with the control arm, and then the ball joint will come right off.
I’m replacing the UCA and the shock plus coil. I’d like to save the knuckle. Angle grinder is an interesting idea. Could that cut through the nut? Wow. I’ll try it as my last resort. Very likely it will come to that. Thanks.
Should I remove my shock when I'm using the angle grinder - or just cover the shock with piece of wet thick cloth? Leaning towards the thick wet towel because of the time + effort to remove that again.
2007 FJ Cruiser Base 4x4 MT
I had the same thing happen to my knuckle. I hammered a size smaller socket onto the castle and impacted it off. Lost a $5 socket as opposed to a $400 knuckle. Fire also helps!
Discussion Starter · #8 ·
Bolt extraction sockets didn't work. Issue is that there none of the "castle" left on the bolt. It's now just the base of the bolt. Angle grinding looks like my only hope. Even if I did hammer on a smaller socket, there's nothing but a smooth surface there.
Just cut it off. Save yourself the stress. And why bother covering a shock if you are replacing it? Have a small hand sledge to pop the ball joint loose once you cut it off. Bonk the side of the knuckle a few times and it will pop out. Support the lower CA so it all just doesn't drop out tho.
Thanks for pointing me in that direction. Used the angle grinder to cut off the entire bolt end with the nut. Had to bang the crap out of it to get to drop, but it's good now.
1 - 11 of 11 Posts
