1 - 9 of 9 Posts
Airaid 511-302 Intake System with SynthaMax Dry Filter
Installed mine today. The 1.5 hours is a pretty good time estimate. I took my time only one little screw up which I corrected quickly. Can you spot it in the pictures?
Pictures, some not taken, some out of order but the Airaid instructions followed to the letter.
The only comment I have has to do with the three wire harness hold downs, no mounting on the new airbox, may not be needed in older FJ's? Easy to fab at least one to hold the harness. Harness pretty stiff, one should be enough.
Test drive, didn't really notice much in the way of sound. The exhaust is pretty throaty. When I wound it up I could here the intake, about same volume as the exhaust. >:D
Here's the Airaid install instructions: View attachment AIR-510-302_inst.pdf
The parts all but the airbox cover
Before - all stock
Remove the 6mm anchor bolt from the resonator. Disconnect the crankcase breather and fuel pressure regulator lines. Loosen the clamps on both ends of the intake tube
and remove the entire intake/resonator assembly.
Disconnect the Mas Air Flow sensor.
Before you remove the air box there are three harness tie downs that have to be disconnected.
Remove the air box cover and filter. Remove the three bolts (didn't get a pic of the inside of the stock air box) :frown Remove the air box
Apply the self adhesive, Foam Weatherstrip onto the air inlet on the Cold Air Box
Mount the Filter Adapter to the Cold Air Box, as shown, using three 1/4-20 x 1/2” Button head Bolts and 1/4” Flat Washers.
Mount the Cold Air Box onto the CAB Mounts using the three 8mm Bolts and 5/16 Flat Washers. Mount the Mass Airflow Sensor on the Airaid intake tube (no pic)Mount the Cold Air Box onto the CAB Mounts using the three 8mm Bolts and 5/16 Flat Washers . Install the airbox
Installed the two fittings on the intake tube. Installed the hump hose and reducer and their clamps. Install the intake tube. Shows the Airaid filter and decal installed
Connect the factory crank case breather line to the 3/8 Barbed Fitting on the Intake Tube and replace the OEM vacuum line on the fuel pressure regulator with the supplied 17” 1/8” line. Connect the 1/8” line to the second Fitting on the Intake tube.
The Mass Airflow sensor connected.
Seal on the bottom of the top, top mounted
Everything tightened and double checked. Install complete.
Trimmed engine cover per instructions.
Engine cover installed
What was removed
The swirl thingy that we've talked about removing in the OEM airbox mod. :grin
G'Day Lee,
Well done mate....
Looks great.... just in time for a tune..... :rofl::rofl:
cheers
Baz
:blueblob:
Almost there, just a thing or two more :smile
You mounted the adapter onto the airbox incorrectly at first. That's the error.
Sent from my SM-N960U using Tapatalk
Dang.....never realized how different the intake on later FJ's is from the earlier ones.
@Lee44 thanks for the detailed write-up.
I am kind of surprised that Airaid does not recommend removing the 90-degree plastic neck from the inner fender well like the TRD CAI. If you feel like taking the lower box out again here's what I am referring to... https://www.fjcruiserforums.com/forums/9277996-post58.html
Figured if you are going to increase airflow might as well go all the way :)
John
John
Here is a better way to increase airflow...
Yep. :cheers:
1 - 9 of 9 Posts
