Maybe I could tell a story of my FJ Cruiser build too.
So, let´s start. I bought my FJ year ago from Germany. It was imported from US in 2006. Manual transmission and Upgrade package 1. About 45 tml in the clock.
First mod, TRD shift knob:
I changed the speedometer to Canada version with km/h scale (part.no 83800-35G70):
Then inside out:
Sound insulation to the roof:
...and floor and everywhere else too:
New 8" speakers (Rainbow SLX 220.20 X-Plain) to the front doors (I made spacers of 22 mm MDF):
Amplifier (Ampire MX-4):
And it´s mounting points (I welded studs for it to the floor):
New radio (JVC KW-AVX840), first mounting with stock brackets. Not good, too much out, tilt would raise the lower edge. (sorry very bad celly pics):
Then with modified brackets, much better:
Next step, CNG conversion. First I installed nozzles to the intake manifold:
Injectors:
Lovato Easy Fast CNG parts installed, the ECU is inside (programmable by laptop). TRD CAI is installed too (stock will not fit any more):
Gas bottle holder, made of stainless steel. The charcoal canister is moved back:
There it is:
The CNG filling valve:
Finnish regulations demand side signal lights, so I installed them to the same spot as they are installed in Aussie/Japan FJs, same lights too (part no. 81730-20192):
I made BMC too for the tires which I ordered:
I painted the frame and axles with POR15 and sprayed rust protection wax everywhere.
I got the long waited goods from USA (includes 5 tires/wheels, RC 6" lift kit, LR UCAs, ARB compressor, Magnaflow muffler and some other smaller stuff):
But the most important thing first, I got the car registered in Finland:
Then inside out:
Injectors:
There it is:
