1 - 20 of 32 Posts
I'll keep it brief.
A: A/C line bent they way I've seen it done.
B: Bent the way it actually clears everything. I marked the line where it contacted the bumper during test fit. Use a block per instructions.
C: Clocking Smitty. Note the missing allen bolts on the end housing. This plate must be rotated so the lever will be in front instead of on top.
D: I used the bracket that came with the bumper to mark a new hole for the control box.
E: Mounted bracket on control box.
F: Control box mounted with remote jack accessable behind bumper wing.
Nice install.Truck looks killer with the winch.Now you gotta get yourself stuck and try out the winch.Let us know how it does.:rocker:
Nice Job on the install!!:bigthumb: Looks great on your TT!:rocker:
Looks nice!
I went with the same bumper and the same winch LOVE them. My control box was bigger, so I took it apart and just mounted the solenoid in the bumper. The box wasn't sealed anyway. Looks great, I love dealing with allpro.
Discussion Starter · #8 ·
Thanks guys.
I have always been a fan of the sleeper look. Function>Form
I'm very happy with the way the All Pro blends in.
You have ne pics up?
Discussion Starter · #13 ·
Here ya go. I added the small hoop.
Looks great.
I don't know what to do with my bumper mounted lights. My wife wants me to get a roof rack. I may put them on the rack or get the hoop for the bumper later.
Looks good! I have an XRC8 sitting around as well waiting for when I get an ARB bull bar to put it in. They dont have the fastest speed, but they are better to have than nothing! I see you have the new revision of the winch too.
Discussion Starter · #16 ·
ok ????? i dont have to charge the system if i remove the line or how did u bend it in place
Use a block to support the lower end(between line and rasdiator) and bend the line in place.
The instructions show a picture of where to put the block.
Discussion Starter · #20 ·
I am looking at the same bumper. Does the bumper attach to where the old one was or are there other mounting points?
It is held on with 8 factory studs in the front of the frame.
The top 1 on each side is hard to reach. Not enough room for a deepwell socket, and a regular socket gets pushed off. I used 3 washers so it would get tight before the stud pushed off the socket.
1 - 20 of 32 Posts
