I had been having issues with what appeared to be the alternator. Alternator died on me last month. Replaced it with Denso Refurb 100 amp (I should have gotten 130 but I was not aware). When installing the new alternator, I noticed that the battery cable that goes to the alternator was rusty and the cap that protects it was somewhat burned too. I cleaned the connector and repaired part of the cable. After installing the new alternator I noticed the alternator output was 14.0 (at the bolt, where the issue was), but the battery was only receiving 13.3-13.6 volts. I again checked the cables and alternator the next day, and for the last 4 weeks or so, my alternator output has been between 13.3-13.6 when driving (based on OBD at the module), and output at the bolt is about the same. When vehicle idles, voltage fluctuates to as low as 12.4 volts, usually when I have a gear and make a stop.
Today I purchased the GM diode hack (GM Part 12135037) and alternator output is now higher in between 13.6-14.00 volts when running, and it stays around there, but at idle it still goes down to 12.4 volts and now it fluctuates more (or greater than before) from 12.4-13.7.
Any pointers as to where to check for other cable issues? Maybe a ground issue? The needle on the vehicle also jumps when at idle. And lastly, does the change in voltage has the potential to damage up my red top optima, should I go back and remove the diode?
I appreciate any help!
1. Volts prior to diode
2. Volts after diode
3. GM Part number
3. GM Part number
