1 - 16 of 16 Posts
Wow good find... unless it's too good to be true.
They had a pic of a one piece and a two piece, i couldn't see how you choose between them there on the website but you definitely want two piece collars
definately the 2 piece one is needed of course......I am figuring these gotto work I mean one of the posts above said to just use hose clamps, and that is not the first time I have seen that answer also
Those would work great.
Any collar should work.. Lots of stuff is like that. Someone locates the standard part somewhere, buys and then sells them as a FJ (or whatever) part at 500% markup.. Ron
PS: I'm not saying that's entirely bad or that you intend to do that, just a comment on merchandising
AL is great stuff, within it's operational limits. Shine it up a little with a buffing wheel and clearcoat it.. My favorite finish for AL is a light sand/bead blasting followed by clearcoat. Ron
I have painted steel ones on right now so AL would be great.
these are the same diameter......and cost about $7 bucks.....would these work???
Unsupported Browser: Reid Supply Company
Just to give you another resource to compare to, p/n 6436K143 from McMaster-Carr they want $8.70 each. I think they increased price due to the price of metals going up, they used to be $7.92. Sounds like your source is legit. The Aluminum ones are less expensive than the steel/stainless steel ones for sure. The 304 SS are $18 each and the 316L are $37 each. Good Luck, Doc
Anybody try either one of these?
i may have to try some of these collars out. while installing my front bumper, i noticed that my sway bar is shifted towards the passenger side, which seems to be causing the sway bar to rub against my coilover spring on the driver's side whenever i make a right turn. i can barely fit a pencil in the space between the sway bar and my driver's side coilover.
I ordered the Reid Supply one's yesterday and at checkout it wouldn't give me a total for shipping and handling so I said WTH how high can it be...right. Thinking probably a few bucks but no more than $5. Well they just sent me the complete invoice and S&H was $9.91 not that this is outrageous but I just thought everyone would want to know. I guess overall it is still like buying one from other sources. Total Invoice for 2 collars shipped from IL to TN was $23.75
I hope they work!
I bought the 304 SS versions here in town for less than $30 out the door. You can find these shaft collars at any industrial power transmission/bearing supply house. They should have them in stock and tend to have decent pricing.
1 - 16 of 16 Posts
