1 - 20 of 42 Posts
Can I get a vote of which Synthetic oil to use. Amsoil or Royal Purpal they all seem like excellent oil. Thanks,
Re: Amsoil or Royal Purpal ?
They are both excellent as well as M1. Cant go wrong with any of them.
I can see this turnin into another coke or pepsi type thread. as stated above both are great as well as others out there. Personally I run RP in everything but I wish I started with mobil 1 only for the price factor. I'm one of those only use one brand for the life of the engine believers. some peeople switch it up alot, I don't know truthfully if it has any adverse effects but it might. lol
Any of the flavors mentioned will serve you well, no worries.
DEWFPO
From what I'm hearing is Mobil 1 Synthetic in the picture too? Competing with Amsoil and Royal Purpal.
REDLINE synthetic:rocker:....
(and they have ATFD6 automatic transmission fluid for the FJCnow, too) :bigthumb:
I used to use royal purple and now use amsoil and i personally feel the engine runs better after 3000 miles on an oil change with amsoil over royal purple, you can tell when idling when its cold, its a smoother idle but maybe its all in my head.
I say neither. Have you seen the prices of high grade synthetic oil!? Good Lord!! I'd throw Penz. synthetic in there just to get through the season. It's cheap and it IS synthetic. Not the best, but good enough.
Most of my expierence has been with Royal Purple so that is what I go with.
all the 100% synthetic oils will do you right.....I have used Mobil1 and now Amsoil for many many years......but would have no problems also recommending Redline or some of the others. I switched mostly because I thought it was a better oil and also because I could become a Preferred Customer and order it myself and have it within a week at my doorstep...as I hated that it appeared when I wanted the Mobil 1 or Redline nobody had it...and other times they all had it. LOL
Just be sure to combine your synthetic oil with a good filter....as the oil gives you the lubrication and heat protection while the filter helps to remove the contaminants and floating particles that all engines produce.
Good luck....
FINALLY!!! Someone has come out with a Toyota Type WS ATF replacement. At $11 per quart, I wonder how it compares to the Type WS at the dealer.
DEWFPO
yeah, not many with WS yet......most still have the Type T and T-IV
If Redline is making it WS compatible then it is good stuff...I used to use their tranny fluid in my motorcycles.
Mobil 1. I use it in everything: cars, pressure washers, you name it, and have done so for years. I've seen tear-downs and the stuff is amazing.
That being said, changing your oil -- regardless of brand -- at the right interval based upon your driving style, environment, etc., is 95% of the battle. That's assuming what you use meets the OEM specified ILSAC specs, of course.
I asked the Amsoil guy about Mobile 1, Red Line, and Royal Purple. He said the additives in the Red Line is the most competitive to the Amsoil, but the Amsoil is still better. Granted, he has a vested interest in his product, but he ranked Red Line the next highest in that group. I think with normal oil change, you're not likely going to feel a difference. Unless you're a racer or is really really hard on the vehicle, all of these oils will be more then adequate.
I have Mobile 1 in the engine and Amsoil in the diff.
Bumping this thread. Are you synthetic converts lengthening your service interval? The Amsoil site states 1yr or 25000 miles!!
1 - 20 of 42 Posts
