1 - 3 of 3 Posts
I need the VSS (Vehicle Speed Sensor) link from the ECM as well as either of the positive reverse signals. If nobody has access or knows someone in Toyota service, we could get a subscription to the database, or I can go spend some quality time with the voltmeter ;)
Adam
I have TIS access while I am at work but I am not sure of what you ae needing. Re-ask in lay-mans terms (ie. the little thingy that sticks out and touches the bigger thingy) I know absolutly nothing about what is under the hood of a car...I just know how to drive the sh*t out of them
VSS - Purple/Red wire found at rear of fuse box, 4 pin plug pin#1
Reverse - Red/Yellow wire found at fuse box, 16 pin plug pin#10
VSS can also be found behind glovebox second plug from bottom, pin#8
1 - 3 of 3 Posts
