1 - 9 of 9 Posts
So I've watched all I can and read all I could. Saw many packages on Amazon and I think I've pieced it all together. I need confirmation from those of you who are experts or had experience with solar setups. All of my camping are dry camping. Usually 2-7 days, non-mobile.
Please advise on which route I should take and if what I've chosen is optimal and can sustain me for my type of camping.
Setup #1 - probably the easiest/cheapest.
-Odyssey pc2150 (I have a brand new one sitting around)
-Odyssey OBC-20A portable charger
-2000 watt Champion inverter generator
-Blue Sea Systems fuse block
-Ampper battery kill switch
-6 gang rocker switch
Setup #2
-Odyssey pc2150
-2x BougeRV 170 watts monocrystalline solar panels
-Victron SmartSolar 100/50 MPPT charge controller
-Aims power 2500 watt inverter charger
Setup will be used to power a Snomaster lp96 fridge, Camp Chef Triton water heater, Seaflo water pump, and miscellaneous items such as charging phones, lamps, etc...
Btw, this setup will be going into a 4x6 off-road utility trailer.
Thoughts?
Sent from my LG-LS997 using Tapatalk
I use a 4thD sole 165 and it keeps my Snomaster 56d going 24/7 365.
Large side of the fridge at 33 degrees and small side at 5.
I run lights under the awning and in the tent, charge 2 full frame cameras, phones, drone. And I have a shower pump. Panel is typically flat. Setup (fixed to tent) it really collects the power.
Definitely go with the MPPT charge controller. It just makes sense to extract as much as you can when the sun is out.
Well here it is guys. Decided to keep it simple which means I am going to be running a 2000 watts inverter generator as needed. The water tank and water heater still isn't installed yet, but that's the only thing left. Here are some pictures.
2013 FJ OD Manual
New FJ owner and I was looking into this mod as well and then the light went on. I have a Goal Zero Yeti 400 Portable Power Station
I bought at Costco years ago for a trip with my Grandson to Yellowstone. I needed this to run my CPAP machine at night while sleeping. These systems are rugged, expandable and if you have any issues and you find at a local Costco, they will always take it back! I had bought both the 400 & the 1000 but after a year decided I really didn't utilize the larger unit and Costco took it back no problem...Now they offer the models with Lithium batteries & WiFi, making the Yeti400 very light weight.
Portable Power Stations & Solar Storage Batteries | Goal Zero
2013 FJ OD Manual
My older Yeti400 is not Lithium and is heavy, inputs for AC, Solar & DC, outputs for all your devices. I also have their lanterns and boom box, very good products. I think I'll just install a couple DC ports, one at rear of the FJ and the other at the center console, this way I can leave the unit on the floor of the rear seat area.
1 - 9 of 9 Posts
