When researching a blinking Error light on my Waeco fridge (too low voltage due to insufficient wire grade and length of wire) I came across this one - an ARB wire loom designed for the ARB/Dometic/Waeco fridge. I did a search, but couldn't find another posting about this so I figured this might help some of you as well.
ARB Fridge Freezer Wiring Loom ? cruiserheads.com store
This wire loom offers two benefits - one, it is a heavier grade wire (10 gauge) and secondly, it uses a merit/hella receptor for the fridge to plug into. This receptor locks the fridge power plug in place as to opposed to a cigarette lighter where the power plug is held in place by friction only. In order to use the merit receptor just remove the red plastic ring on the plug that goes into the cigarette lighter - insert the plug into the merit receptor and "click" - it stays in place. A much more positive way of holding the plug in place under off-road conditions.
An interesting observation is that the new ARB fridge is manufactured by Dometic - which bought Waeco a few years ago. So the ARB fridge is using the compressor and the controls from Waeco. Thus the performance specs are identical. ARB worked with Dometc on the new shell for the fridge. Here is some background and a comparison with Engel, from ARB themselves.
http://www.arbusa.com/uploads/PDF/newProductAdvice/FridgeFreezerSalesGuide.pdf
I just installed the ARB wiring loom, running it straight to the aux battery. Now I can use the Turbo mode for cooling down the fridge even when the truck is not running. The added power due to the thicker cables ensure the fridge will get the juice it need, instead of fighting a voltage drop due to poor wiring.
Keep em' cool
Bjorn
Keep em' cool
Bjorn
