1 - 10 of 10 Posts
ATX Thugs and BF Goodrich All-Terrain T/A KO
Guys, I just got my ATX Thugs in 17's and the look hot. Ok now I need wheel locks. Who makes wheel locks for the Thugs? The guys at the Tirerack have no idea! I brought the lug to the Autozone and nothing looks like it. Thug owners please respond.
What sise tires are you running and what offset did you use. Tirerack tells you to get -6 offset, but I'm concerned that that is too agressive. Thanks
Get yourself some narrow spline drive type. It prevents easy theft and comes with a socket that won't scar the lug holes when mounting and dimounting, Gorilla should have something for you. All the major auto stores carry some version of these. Or just search a little harder on here and you'll find the answer.
Some gorilla lugs should be the solution, lets see some pics of thoseThugs on the FJ!:rocker:
I'm using black "Gorilla" locking lugnuts on my 17 x 8.5 AR Thugs (with rivets). It looks great! The model number for the lugnut set is "GOR 26144HT". You should still reconfirm the numbers just in case. I hope this helps?
So -6 offset, what size are the tires? I can't tell from the pic 2?5/70R17.
1 - 10 of 10 Posts
