1 - 18 of 18 Posts
I always air down when going off road... but I hate to air back up because it always seems to be raining, cold and dark when I finally get off the trail. After years of searching and coming up empty, I decided to build my own automatic tire inflator using an inline regulator designed for air tools.
This video shows you what I came up with in order to never have to sit next to my tires in the rain again!
if you like this idea and want to build one yourself you can find a parts list at How to make a automatic tire inflator. I've used this setup a bunch of times now and it works great. You should see the looks on peoples faces that are sitting next to their tires airing up, when I just walk away and they hear it automatically stop when it's done :)
Let me know what you think.
X2. Nice!
I'm thinking this might work with the 2-Way Air system as a better regulator than the one that comes with 2-Way.
Very cool idea. I was secretly hoping you'd figured out how to adapt a military CTIS system to the FJ though.
Glad to see you are still with the FJ community , stealing this idea :D
How about a version that fills all 4 tires at once? It's a lot more hose to wrangle, but then you don't have to switch it for each tire.
Discussion Starter #11
Does the inline pressure regulator just block the air flow, or does it blow off/dump the air out allowing the pump to continue to running?
I thought I read something in reference to the ARB compressors not to allow them to run on a shutoff type line...
Discussion Starter #13
I'll confess i looked long and hard at those... and they are very cool, but the ROI on that was going to take 1,000 years to pencil out :)
Discussion Starter #14
This regulator blocks the air when the tire PSI and regulator reach equilibrium. The Viair pump i run has a solenoid that shuts the pump off when the line pressure reaches 100PSI. Certainly not all pumps have a solenoid shut off but any of the pumps that can be attached to a small air tank will. If a pump doesn't have a solenoid shut off you can ad a waist gate but at some point this contraption is getting out of hand and it's back to the stool :)
Discussion Starter #15
I'd never leave this community... I still love my FJC... It killed me to demo the tire inflator on the GX470 in the video instead of the FJC but I had the GX out.
Discussion Starter #16
So I could add hose wrangler to my resume if I did that :)... I was thinking about a set up to fill one side at a time... That seemed less attack of the killer octopus and might not trip me up in the dark. Might have to think about this a little more.
Desert Moderator
ARB compressors have a pressure switch preset to 100 PSI - this will work fine with them.
1 - 18 of 18 Posts
