1 - 20 of 23 Posts
Well I finally got around to taking some pics of my install. I used some 3/16 brake line with 1/8th pipe adaptors to a 1/8th pipe FFM Tee. Then -3 steel braided line into the cab.
Excellent! Thanks for sharing, I've been meaning to get this project started myself! :)
Are you using any special adapter there, or just a simple t? Did you get the crazy fitting size from somewhere that's easy to source?
G&J in Ontario Ca is 1 of the largest aircraft/hose sources in southern Cali. The owner told me that they have been using 1/8th NPT in 10mx1 fittings for 20 plus years on VW brakes. So he sold me the 1/8th pipe fittings and they seal perfectly with T-tape.
Wow! looks nice. what other gauges you going to install? Is there any reason you need extra attention to the oil PSI?
It's the port that the factory dummy light is plugged into. Tranny temp will go underneath and the Lowrance HD GPS will go next to it. I come from a racing background and have never or ever will trust a dummy light. The day after I installed the gauge I went to glamis and the factory dummy light came on when I was in the dunes, gauge was reading perfectly it went off by it's self but if I wouldn't of had the gauge I would of been freaking out.
Also with 9psi and 4 low I went right up the center of olds no problem and threw the dunes.
Cold idle is 80psi
Warm idle is 25psi
Cold driving upto 95psi
Warm freeway cruising 40-80psi
Needle moves as much as my tach.
Is this on a '07-09 running 5W30 dino
or...
a '10-11 running 0W20 synthetic?
Thanks, DEWFPO
Thanks for the data.:cheers:
DEWFPO
Any reason you chose a mechanical oil pressure gauge over an electrical gauge ? I would think teeing for the sending unit, and running a wire inside would be easier...(and if the off-road vibration causes that gauge to leak in the vehicle, it'll be a mess :lol:)
Sorry, I just saw I asked the same question about an electronic oil gauge which is already on this thread. I am still getting the hang on how the forum works. I am grateful for all this knowledge.
caver bob
Discussion Starter · #19 ·
After 10000+ miles on my and the rest of my teams off road race trucks we've never had a leak on any of our mechanical gauges, the only failures we've had were electric senders going bad.
1 - 20 of 23 Posts
