This is my first mini-mod. I purchased the Baja Rack Drop-in Basket, because I wanted to retain the OEM look/seal with the roof. It surprises me that the front-half of the roof is not truly utilized by the OEM rack alone.
I wanted to share a few comments and pointers for those who want to install this:
- I am very happy with the quality and fitment of this product.
- It attaches to the OEM rack with upper and lower clamps and fasteners (5/16" stainless steel bolts, washers, lock washers, nuts, nylon washers)--you'll need 1/2" sockets for the bolt heads and nuts.
- After attaching the clamps and fasteners with the rack in place atop the OEM one, it is important to position it:
(a) with regard to its anterior (forward), posterior (backwards) location. If you're mounting a light bar up front, you will need to leave room for this.
(b) with regard to superior (upward) and inferior (downward) location. The weight of the basket pushes the rack toward the roof. If possible, place a temporary shim (I used a gardener's knee pad and some wood veneer), to keep the basket raised away from the roof. This will allow you to tighten the bolts with the rack in its intended position without putting strain on the stainless steel bolt threads/nuts. Alternatively, you can have someone (other than your short spouse), hold the rack upward while you tighten.
