Actually disregard, some searching old threads revealed that I can just replace the ribbon cable itself Thanks to @rev. 3:11 Hey bro, so the 8 pin cables you linked should work for this right?
Yes I think I got it covered Thanks to an old thread from here. Ordered new ribbon cables on Amazon.Is that just a basic commercial ribbon cable that with exposed contact fingers at both ends that plugs into push-in connectors? If so, it's known as an FFC (Flat Flexible Cable).
If it's an FFC, all you need to know is the pitch of the contact fingers, the thickness over the fingers, the number of conductors and the length, and it should be available for less than $1 from any of the major electronic component houses.
Post some good quality photos of both ends of the cable, the number of conductors, and the length ... we use many of these cables in our products ... if I happen to have something usable, I'll send you one.
The OEM ribbons are same on all years (I have an '07 & '11)Actually disregard, some searching old threads revealed that I can just replace the ribbon cable itself Thanks to @rev. 3:11 Hey bro, so the 8 pin cables you linked should work for this right?
