1 - 6 of 6 Posts
Hey Everyone,
Working on my next set of mods and with some inspiration from Nestahedition I was going with an Oznium switch install that will control 2 Blue Sea Dual USB power outlets. I have been looking and I have found a lot with a single switch to a single outlet, but nothing with one switch controlling 2 outlets. I am not the best when it comes to electrical, but I drew up the below diagram based on my assumption of how the install should go. Can you guys weigh in and let me know if I am on the right track? Thank you in advance for the help.
As long as the switch you're using can handle the max amperage you're planning to have available at both both USB ports it should be fine the way you have in your diagram.
What switch are you using?
Or stick a relay in there and don't worry about the switch's power capability
Hey lqdchkn,
For some reason I am not able to post with links.
It is an Oznium anti-vandal switch that say it has a 15 amp top end
On the BlueSeas it shows the total output at 2.1 amps. figuring x2 that would be 4.2 amps total out pulling on the switch.
Planned on protecting the system with a 5 amp fuse. That sound right?
1 - 6 of 6 Posts
