I have a stripped weldnut on the frame, it's one of the recovery point bolts so 12x1.25mm I believe. Bolts fine but as you tighten you can feel it skip. I had to chase the threads a while back and I'm guessing it didn't leave much in there.
I figure my best bet is to drill out and move to a larger bolt. Only a 14mm might be too big for the weldnut.
Is there a SAE bolt size slightly bigger than 12x1.25 that would work better in this situation.
Thanks in advance.
Thanks in advance.
