1 - 4 of 4 Posts
whats up- i just tried to turn my headlights on but both are out, everything else works including the brights, I checked fuses and all is fine does anyone have a suggestion
thanks all
I hate when someone posts a question, it get's 80 view's & no reply's. I see your new here with 4 posts & I don't know how long you have had your FJ or how old it is, but just a suggestion: There is another fuse box under the hood, I'm not sure if the headlight fuse in in that one. I don't have my manual in hand & I can't go look right now. Check your manual in the glove box. It could be that fuse in there. If not I would just stop at a dealership & ask if they could check it out. Good Luck with that & post up what the problem was after you find it.:cheers:
Did any of the suggestions from your previous thread not help?
Have you checked the bulbs themselves to see if the filament is broken?
It could be coincedince that both burned out at the same time.
1 - 4 of 4 Posts
