1 - 6 of 6 Posts
The brake lights are not functioning, the brakes are. I believe the brake light sensor is working because the FJ cannot be taken out of park. The back running lights are functional, so I think there is a problem with the wiring. There was a tow package crudely installed and I have removed most of it. Not sure where to go from here.
Double back and check every wire you touched removing the old trailer harness.
If the brake lights don't come on, and the transmission shift interlock won't release, then the problem is most likely the brake pedal switch just above the pedal. These are not expensive or difficult to replace.
But do inspect the botched trailer wiring carefully anyway. Why someone would hack something in when the Toyota tow package harness kit is available is beyond me.
1 - 6 of 6 Posts
