1 - 9 of 9 Posts
Hey, I was looking at places that are prone to damage and places that I have damaged off road and I always am hitting the rear trailing arm bracket. In a recent trip off road, i bent one small part of it to where it touches my actual trailing arm which made a faint squeek. Problem solved with a little grinding. Looking at Allpro's skids that are $89 bucks, I could make these for literally about $5 and an hour and a half or two of work.
http://www.allprooffroad.com/images/stories/fjcruiser/linkskids_04.jpg
My question is: Has anyone made these yet and/or does anyone have the dimensions of their own or allpro's versions?
I'm not really crazy about the design of most of the lower link skids I've seen, primarily because they still represent a bit of a target. Graham (gsgmac) and myself have these skids installed on our FJ's:
As you can see, they're designed to slide over objects, not offer anything in the way of a contact point (in addition to adding substantial protection to the lower links). If you're designing skids you might want to consider making them as contact proof as possible.
Jim
Thanks jim, that looks really good... Makes me go back to the drawing board. I'll see what I can do this weekend
all i need is dimensions to make one
Grab a pad of paper, pencil & tape measure then head out to your FJ and measure away. Doing it this way will make sure you get all the dimensions you want/need.
Make sure to post your final results. :)
Discussion Starter #9
its a whole lot more than you think. I didnt realize that there is a bend in the bracket from the plate that the bolt goes through to where it meets the frame. This really gets to be a pain in the ass when you are thinking about welding right beside the gas tank...
1 - 9 of 9 Posts
