1 - 7 of 7 Posts
Single Remote Bypass Kit is BMK-21. $191.00
Needed Optional Parts:
1) BP-44 adapter kit for oil sending unit = $14.75
2) BP-89 for oil return = $8.00
PDF instructions: https://www.amsoil.com/bypassfilters/instructions/BP83.pdf
Dual Remote Bypass Kit is BMK-23. $269.00
Needed Optional parts:
1) BK295 Spin-on Adapter = $56.25
PDF: https://www.amsoil.com/bypassfilters/instructions/BP252.pdf
By-pass filter capacity:
EaBP90 = 1 qt. $37.15
EaBP100 = 1.5 qt. $40.25
EaBP110 = 2 qt. $46.55
***All above pricing is retail. Please PM for discounted pricing.
Brent,
I assume the parts you have listed above are specific for installation on the FJ?
The .pdf you have listed is a generic install, do you have specific instructions for the FJ?
DEWFPO
Yes, those are the parts need for FJ installation. You also need to chose your by-pass filter size. The EaBP100 would make total oil capacity to 7 quarts for convenience.
I don't have any specific instructions for the FJ. I don't think any FJ has the BMK21, so it's calling you :)
Two options are available for returning the filtered oil to the engine. The first uses a self-tapping hollow bolt (BP-40) and allows the oil to be returned to either the oil pan or a rocker arm/valve cover. The second, which uses an optional swivel fitting (BP-89), returns the oil to the oil filler cap already installed on your vehicle.
The oil filler cap is easier and more convenient.
1 - 7 of 7 Posts
