1 - 7 of 7 Posts
So my ABS / Brake /vsc light came on . I ran the scan and it shows C0215 . I tried swapping the rear ABS sensor but still the same . Any ideas on what else to look for ? I did unhook some bumper lights that were feed through the large grommet from the engine bay to the cab . I can not see that i damaged any wires in that loom ? but its very hard to see in there .
Admin
I broke my abs wire when installing my suspension years ago... perhaps you have a break in the wire.
The easiest way for me to find it was to slide my hands along the wire and feel for a thinner section.... indicating that there was a break inside the insulation.
Same Code . I would clear it then My guess is the scanner runs a test again and it would show the same
i will see what i can find . it cant be anything to crazy .
1 - 7 of 7 Posts
