I am on my second FJ. My 2007 was great and I had no issues with it so when a hail storm destroyed it, I purchased an identical 2010. I have had a few issues with it. First, the rear cabin leaked terribly! Getting them to fix it correctly was like pulling teeth. It was only after I threatened to just give it back to them did they finally remove it and seal the leak properly (roof rack issue). My second issue is paint color. It looks like the front piece just above the grill has been repainted. It is a distinctively different yellow color. Small issue but it annoys me.
My biggest gripe though is cabin noise. Does anyone else have this problem? It sounds like a wind tunnel inside the car when the windows are up. It is very noticeable even at lower speeds. I complained to the dealer and I get your typical "you're nuts" type of answer and they tell me it is normal. My 2007 did NOT sound like this. I have also noticed considerable engine noise in the cabin. It sounds like the engine makes a noticeable tap tap tap noise. I have to turn the radio on to drown out these noises.
One thing I do like about the 2010 over the 2007...the side sun visor! Finally! The front sun visors were completely worthless for side shading.
Any input would be appreciated. Thank you
