21 - 26 of 26 Posts
Discussion Starter #21
So is it as easy to put back as it is to set up?
I would say so, the first time or two takes an extra 5 minutes. After that takedown is just as quick.
Can you fold it up with sleeping bags in it?
I've heard mixed things from other people, but I have 2 queen size pillows and two queen size comforters (In a waterproof bag), along with 2 flashlights, travel toothbrush in mine closed up right now.
How hard is it to take on and off? I would need to leave it off unless I went camping otherwise it won't fit in the garage.
IMO its a pain to take on and off, 8 bolts that go relatively fast on a stock roofrack, but I've heard are painful to remove on some low profile aftermarket racks. Then two people to remove the tent from the roof.
I have seen a thread somewhere else on the forum though, where someone developed a lift system inside their garage to lift it off of their FJ and store it against the ceiling when not in use.
I'm curious about weight - nobody's really been able to identify what the real capacity of the stock bars (not the crossbars) are. Have you had 2 people up there? Any noises or other signs of damage?
Is the Camping Lab Tent available only through the manufacturer/distributor or are there other places that it can be purchased?
I believe the roof, or roof rack of the FJ is rated for 500 pounds. I have had at least 400 pounds in mine with 2 people (Myself and Brother) Plus the weight of the tent itself. Never had any issues, heard any noises, or noticed any wear.
So...no ladder extension required?
I'm getting ready to pull the trigger with the same setup on an OEM rack and figured I'd have to get a ladder extension based on the specs.
Looks like yours is working just fine without one...can you confirm?
Thanks a ton, great write up - Bob
Discussion Starter #26
Wow just saw this post when I was coming in to ask a question about that.
It has worked wonderful without an extension.
That being said, I just ordered a lift kit, and I will be needing an extension when I get a lift. I noticed camping labs has them on backorder.
Does anyone know if any of the other companies ladder extensions are compatible?
21 - 26 of 26 Posts
