1 - 15 of 15 Posts
I am trying to get these off (to install the custom FJ Bazooka bracket) but they don't seem to be moving, just stripping the screw. Anyone remove them?
I am assuming you are talking about the plastic cleats, it is just a long screws so when you unscrew it it gives you that feeling, keep turning it will come out..
I am trying to but it is stripping the screw. Then I looked with a flashlight and it appears that the screw is set in a metal brace or something, so I was concerned.
This is an FJ without the stock sub.
Do you mean those little plastic cleats on either side for hooking onto grocery bags? If so, yes.... unless they changed something for the 2008 models. I don't think they would because those need to be removed to pull the plastic in the rear if you need to get in behind it for wiring or something. Just get a metric socket set.
Discussion Starter · #8 ·
The pdf in this thread (removing stock subwoofer) shows a bolt needs to be removed, but I have a 2008 without the stock sub and there is no bolt, its a screw, inside a metal brace (circle) and its not turning.
Geeeez, I just posted about this, with picture, and then scrooled down to find this post. I think Doomsday and I are talking about the same thing. Here is the picture I posted:
I'm not hijacking just trying to get the same information, I think.
Formerly FJ_Marine
nevadaesh, thats it, thats the phillips-head screw that isn't budging.
So it can't be unscrewed? Why is there a screw in there. :flame:
Take it to the dealer, they have a special 10mm socket that can remove it. :rofl:
Just kidding, use a regular 10mm socket and it will come out just fine.
when i was removing all my panels, i went for a phillips. a slight turn made me realize it wasnt going to budge it without stripping it. had to got for a 10mm socket and it did the trick. cant even get a good grip on a nut driver for those.
1 - 15 of 15 Posts
