1 - 13 of 13 Posts
Models:
- 4WD with manual (6M)
- 4WD with automatic (5A)
Exterior Colors:
- Titanium Silver
- Black Cherry Pearl
- Sun Fusion
- Voodoo Blue
- Metallic Black
Interior Material:
- Cloth
Interior Colour:
- Dark Charcoal
Standard Features - Interior:
- Audio: AM/FM CD with MP3/WMA Player, Audio Auxiliary Input Jack, 6 Speakers
- Climate Control: Air Conditioning, Cabin Air Filter, Rear Seat Heater Ducts
- Seat Material:Water Repellant Seat Fabric, Full Fabric Seats
- Front Seat Type: Bucket Seats
- Driver Seat Adjustments: Driver Seat Recline Adjustment, Driver Seat Vertical Adjustment, Driver Cushion
Height, Headrest-Vertical, Driver Foldable Armrest
- Passenger Seat Adjustments:passenger Seat Recline, Headrest-Vertical
- Rear Seat Type: Rear Bench Seat
- Rear Seat Adjustments: Fold Down Rear Seat (60/40)
- Power Door Locks
- Instrumentation: Black On White Meters, Tachometer, Voltmeter, Water Temperature Gauge, 4WD Indicator
- Passenger Vanity Mirror
- Power Windows with Driver Side Auto Down
- Body Colour Center Stack
- Metallic Shift Knob
- Driver Footrest
- Metallic Dash Accents
- Fabric Headliner
- 3-spoke Steering Wheel, Tilt Steering
- Front Passenger Seatback Pocket
- Cargo Lamp
- Rubber Floor
Standard Features - Convenience:
- Digital Clock
- Front & Rear Cup Holders
- Accessory Power Outlets
- Cargo Area Tie-Down Rings, Shopping Bag Hooks, Cargo Area Side Storage Compartments
- Door Map Pockets
- Coat Hooks
Standard Features - Safety:
- Dual Stage Driver & Passenger Airbag Supplemental Restraint System (SRS)
- Front Passenger Occupancy Classification Indicator
- Side impact Beams
- All-Position 3-Point Lap & Shoulder Belts
- Adjustable "B" Pillar Shoulder Belt Anchors
- Rear Seatbelt Pre-tensioner and Force Limiter
- Anchor Points for Child Restraint Seats
- Rear High-mount Stop Lamp with LED
- Front Tow Hook
- Assist Grips
- Power Tailgate Lock
- Warnings: Low Coolant Level, Door Ajar, Head Lamps On, Front Driver and Passenger Seat Belt Warning
Standard Features - Exterior:
- 4-Door Sport Utility
- 17" Aluminum Alloy Wheels, Wheel Locks
- Dual Exterior Mirrors, Foldable Exterior Mirrors
- Flip-Up Rear Hatch Glass
- Electric Rear Window Defroster
- Tinted Glass
- UV Glass Protection
- High Solar Energy Absorbing Window Glass
- Unique Grille, Fender Flares, Rear Step Bumper, 4 pin Trailer Wire Harness, Styled Splash Guards,
- Blacked-out Side Window Frames
- Variable Intermittent Wipers
- Halogen Headlamps
- Auto Headlamp Cancel System
- All-Weather Floor Mats
Standard Features - Mechanical:
- Engine
4.0 Litre, 6-Cylinder, DOHC, 24-Valve, Variable Valve Timing with Intelligence ( VVT-i), Sequential Multiport
Electronic Fuel Injection, Electronic Throttle Control System with Intelligence (ETCS-i), Acoustic Control Induction
System, Engine Oil Cooler, Heavy Duty Battery, Starter, Alternator and Heater, Hood Struts, Stainless Steel
Exhaust System
- Compression Ratio
10.0:1
- Horsepower hp
239 @ 5,200 rpm (premium fuel)
- Torque lb.ft.
278 @ 3,800 rpm (premium fuel)
- Suspension
Front: Double Wishbone Type, Gas Shock Absorbers, Coil Springs, Stabilizer Bar
Rear: 4-Link, Lateral Track Bar, Gas Shock Absorbers, Coil Springs, Stabilizer Bar
- Drivetrain
4WD Full-Time, Vehicle Stability Control (VSC), Centre Differential Lock, Rear Differential Lock (6M only), 2-Speed
Transfer Case, Traction Control (TRAC), Engine, Fuel Tank & Transfer Case Protector Plates
- Transmissions
6-Speed, Manual, Overdrive
5-Speed, Automatic, Super Electronically Controlled Transmission (Super ECT), Overdrive, Gate Type Shifter,
Lock Up Torque Converter
- Brakes
Antilock Braking System (ABS), Electronic Brake Force Distribution (EBD), Brake Assist (BA), Front Ventilated
Disc Brakes, Rear Discs
- Steering
Rack & Pinion, Power Steering
- Tires
P265/70R17, All Season, Full Size Spare Tire with Alloy Wheel
- Curb Weight kg (lbs.)
Manual 1,945 (4,288)
Automatic 1,946 (4,290)
- Towing Capacity kg (lbs)
2,268 (5,000)
- Payload kg (lbs)
601 (1,325)
- Cargo Capacity m³ (cu.ft.)
Behind Front Seats-Max. Cap. 1.89 (66.8)
Behind Rear Seat-Max. Cap. 0.79 (27.9)
- Fuel Capacity l(Gal.)
72 (15.8)
- Fuel Consumption City/Highway L/100km (mpg)
Manual 14.5/11.2 (19/25)
Automatic 13.6/10.3 (21/27)
Options Packages:
B Package (6M):
- Active Traction Control system (A-TRAC)
- Privacy glass
- Cruise control
- Clearance and back up sensor
- Roof rack
- Power remote mirror
- Rear window washer/wiper
- Keyless entry
B Package (5A):
- Rear Differential Lock
- Privacy glass
- Cruise control
- Roof rack
- Keyless entry
C Package:
- B Package plus:
- In-dash 6 discs CD changer
- Steering wheel audio controls
- 2 additional speakers
- FJammer high grade audio system
- Front seat mounted side airbags
- Front and rear head/side curtain airbags
- Multi information display
- Outside temprature gauge
- Altimeter
- Roof rails
- Variable Intermittent wipers
- Leather wrapped steering wheel
- Metallic shift knob
- Color keyed interior door trim
- 400W (115V) power outlet
Discussion Starter #2
The info above is from a pre-order form and was correct at Dec 20,2005. If anyone notice any changes since, please correct me, thanks.
Here are the prices (thanks to rjp):
Base Model: $33900
B Package (6M): ?
B Package (5A): ?
C Package: $38900
Freight and PDI are extra
If anyone knows the prices for B packages or freight and PDI, please post them.
$33900 for a MT 6 or auto?
Both of those prices are for the 6 spd. The sales lady said she would email me the price for the B package but hasn’t sent anything yet. I'll post it as soon as I have it.
Looking for a Silver 6 spd C package myself - just need to see one of these things in person before I actually put a deposit down though.
On the C package, does anyone know what the "Roof Rails" are?
Is that a typo? should it be rock rails?
Why are standard features like "metallic shift knob" and "variable intermittant wipers" also listed on the C package? To make it look bigger and better?
They also repeat various items like: the FJammer audio system which would automatically include 6 discs and 2 additional speakers, and multi info display would include altimeter, temp gauge.
RubyConman.....Toyota dealers can be Conmen too!!
Let me know your e-mail and I'll send you a pre-order form I got from a dealer (it's too big for posting here). I just double-checked it and everything I posted above is as it's written in the form.
Maybe the knob is shiny and wipers swing better on the C package - I dunno :)
Just received a message from my sales person; she received new information showing the price to be lower than her original quote. It's not terribly specific but she said the FJ would be starting at $30 K (base) and topping out at $37 K (C package). This does not include PDI, freight, GST and, for you non Albertans, PST.
Almost forgot, she mentioned that official pricing will be available on the Toyota.ca website by the end of January!
We will see if our comments/questions on Toyota Truck price will affect Toyota Canada on Fj Pricing.
goleafs said:
C Package:
- B Package plus:
- Altimeter
- Roof rails- Variable Intermittent wipers
They change it on the web site (Toyota.ca) now is a Roof rack! Duplication because its already in the B package.
Options Packages:
B Package (6M):
- Privacy glass
- Cruise control
- Roof rack
- Keyless entry
You mean to tell me that the base model does NOT have a rear wiper?? WTF? isnt that a saftey hazard or something
1 - 13 of 13 Posts
