1 - 15 of 15 Posts
I was ordering a set of Nitto trail grapplers M/Ts in 295/70/17 but Discount tire is out of stock and on backorder.
My other options are get the same tire in a 35 series or go for a BFG KM2 in a 285/70/17.
I just ordered a Icon Extended travel Stage 1 kit with LR UCA's. I will be running stock 17" Wheels. I'll be getting wheels next year. So I guess I will be needing the spidertrax wheel spacers to run the 35's and do a body chop mount.
Any other negatives to running a 35 series tire?
Or should I just get the KM2's?
Downsides: Gas mileage is gonna suck.
If it's your daily driver, I would stay away from anything bigger than a 285 especially the way gas prices have gone up lately. Good luck with your decision!
Yea I'm pretty sure I decided on the 285's. From what I have read and heard 35's are to much trouble.
33 km2's on order.
Thanks guys
i think if u wanna run 35's u need to really have a 6" lift and a doby mount chop. im sure some fit them with out 6" but alot of trimming.
No you can easily fit 35's with a 3 inch lift. You will just need to do a BMC and upper control arms. You may not even need the upper control arms, but it'll drive like sh!t if you put either lift on. Hence the debate over 6" vs 3" because you can fit a 35 on both lifts, and the 3" some say give you the same clearance as a 6" plus you'll have a lower center of gravity.
Increasing the diameter of the tires that much over stock will make your final gearing quite a bit higher, which will hurt your acceleration and mountain/towing performance, and make your cruise control almost useless (especially on the 5AT transmission). But you can always re-gear your differentials to fix that, it's only money. :)
For those of us with 2010s, that will end up being quite an adventure though. At least until someone finally comes up with a kit for us.
I have the 295 trail grapplers and the only problem I had with the stock wheel backspacing was rubbing the uca's (no rubbing on the body mounts). I would say that if you have aftermarket uca's you have a good chance of no rubbing at all even without a bmc (especially with 285s which I ran for 40k miles and never had a single issue with rubbing)
Patience... it'll come out, they won't forget about you guys.
the info in the forum and this thread helped me decide to go with the 285's. I'd been running 265 Nitto TG's for 4 years and recently installed an OME lift with Light Racing UCA's. Had the Nitto TG 285's installed today, look great and no rubbing at all. Thank you all for posting opinions and experiences.
Discussion Starter · #14 ·
I went with 295/70/17's Cooper Discoverer STT's. Really nice looking tire and from all the reviews I have read it seems like I have made a good choice.
Just waiting for my lift and there going on.
Quick pics more to come
1 - 15 of 15 Posts
