1 - 13 of 13 Posts
So i am a volunteer fire fighter and looking at ways to run a radio antenna and mounting. Wondering how everyone is mounting there antennas. Our antennas are a little larger then normal cb mounts.
I Have a V-8!! Moderator
G'day.
No need to delete if you moved it into the CB section.
Unless you want the whole thread deleted...
Cheers
Baz
What band or bands is your dept using? Will it be used strictly for public safety?
What I did was used a bandi mount from all-pro off road and drilled it out for a UHF barrel connector. I went with this style because I had a few antennas that have a UHF base already. You could adapt it to a NMO just as easy. Then I used a comet CA-2x4SRB antenna. Our 800mhz P25 system is OK if you're near a repeater, a handheld will work for that. There is another band around 154mhz that dept of forestry, CalFire, county, OES, everybody uses it. With that antenna it is a 2m/70cm ham antenna with extended bandwidth that covers some public safety freqs. Inside I have a dual band dual receive radio so I can be multiple places at once. There is also a few mounts by comet and diamond that will easily work on a FJ. There is some that pinch a door, some that will grab the roof rack, or go through the roof. I have since moved the comet antenna from the bandi to a mount on the right side of the rear door. If your dept uses 800mhz I would probably roof mount it.
We use two different radio systems. For the VHF, I used a Boztec Ham antenna mount on the rear door hinge. For the 800 MHz trunking system, I used a clamp on antenna on the top center of the rear door.
If you look at Boztec, they make amount that will accept an NMO mount.
Indeed they do. :bigthumb: Wish the weld went all the way down, but oh well. I'm still gonna get one and run it with a 55-inch Comet SBB-7NMO which should reach well above the roof's groundplane for a little better reception in the wide open spaces of South Texas than my current 38-inch SBB-5NMO.
HAM Radio Antenna Mount | BozTec
1 - 13 of 13 Posts
