21 - 35 of 35 Posts
i have ordered them from this seller and shipping was fast. Great switches i ordered 2. these are some nice switches.
eBay Motors: TOYOTA TACOMA OEM FOG LAMP SWITCH 05-07 (item 300191572612 end time Jan-27-08 08:11:36 PST)
Yes, they are cheap and nice.
Though you also need to buy the plastic (terminal) connector and the 4 splice wires from your local dealer.
Here are the P/N's;
90980-11090 Electrical Connector, Terminal ~ $3.49
82998-12340 Repair, Wire splice ~ $5.46
Discussion Starter #23
You also need to buy the plastic (terminal) connector and the 4 splice wires from your local dealer.
or you can solder wires directly to it and shrink wrap. i would just and bullet connectors to the wire so you can remove them when you want. This is another cheap solution.
found this on another thread. here are the pin outs.so , now you have part numbers and pin outs.
Just to be clear, this pinout is for the original switch listed on EBay, not the $13 switch as picture by Oscarr. Oscarr's switch only has 3 connections to the back of it.
So then, does anyone have the pin out for the switch Oscarr pictures (00550-35976)?
I checked mine from the Honda / Isuzu - it is almost the same but it has a fifth terminal and an LED that lights up when energized - exactly the same size, shape, etc. made by TEC. I think the fifth prong may have something to do with an override - when the high beams were activated the fogs went off.
I figured it out....
IPF Lead -> terminal on Taco Rocker Switch (with light on switch UP)
Black -> Top (Ground)
Red -> Middle (Hot)
Black/White -> Bottom (Relay control)
jhaydeno, you have any pics of this switch you speak of? or know where they can be seen?
Residual, take a peek at these pics - If you need more info let me know. I haven't actually stuck it in a toyota hole, but it is exactly the same size and the blank off is the same piece as the toyota switches, atrac, vsc, reverse, etc. I can ohm out pins and map it if anyone wants to try one. Again, this is a TEC switch used in Honda / Isuzu for the last 8 or ten years.
Discussion Starter #32
taht switch looks good. it looks differtent from the tacoma switch. but it has an led.... :) the corners look more sqaure.
do you have a pics next to any fj oem switch??
would you be able to get a plug and pins for it???
I'm sure the plug is still available for it - it is still used in the rodeo's. You could also go to any junkyard and cut one out of any Isuzu / Honda wiring harness!
I'll pop a blank cover out of the FJ tonight when it gets home (wife stole it) and get a pic next to the toyota switches.
Is eBay item number: 180245391012 the same switch as you guys have used?
Thanks,
Paul.
was it ever determined if these switches fit?
21 - 35 of 35 Posts
