1 - 3 of 3 Posts
2007 FJ 4WD my check engine lights go on for a few hours while Im driving normal. Then they turn off. I noticed that during the time the check engine lights are on , my transmission performance shifts to 4D Even though it still shows being on regular drive.
When I try and shift back and forth from D to 4D there is no change in rpms or performance. It stays on 4D performance.
any ideas anyone?
Use an OBDII code reader to see if there are any stored or pending codes.
Certain transmission problems can cause the transmission to lock itself out of 5th gear, but I don't know if that will trigger the CEL.
Do the basic no-brainer stuff first, check transmission fluid level when warm.
Next, get an OBDII reader that you can take with you and immediately do a code check while the CEL is ON.
1 - 3 of 3 Posts
