1 - 20 of 25 Posts
Received my new Exp-1 rear bumper and light kit just before the holidays and am in the process of the install.
First off - the bumper is well designed and should serve my needs. I received it bare and had it powdercoated satin black to match my custom rear ladder.
I encountered some issues in the install that I want to bring out - and would like to recommend a couple of minor redesign areas.
Here's the official Toyota PDF file for the hitch installation, this covers the complete OEM bumper skin removal:
http://www.fjcruiserforums.com/forums/attachments/misc-technical-discussion/33959d1262797852-oem-hitch-harness-toyota_fj_cruiser_tow_hitch-1-.pdf
The Exp-1 uses your old rear bumper corners, but not the center section. So remove with care...
Your FJ should now look somewhat like this (color may vary)
I would strongly recommend removal of the spare tire.... I had to remove the ladder.
Remove the tow hook on the drivers side. Notice the rust after only 39K... I would suggest spreading some POR-15 on the areas the new bumper mounts..
I have the towing kit with a brake controller - and the wiring all needed disconnected from the frame in order to mount the bumper. All the little "flaps" held onto the body with plastic clips need removed as well.
This is the rear bumper slid in place over the frame - do this with your rear door open!! You can now see the mounting tabs on the passenger side that attach under the frame and behind the frame...
Here you can see why the trailer/towing wiring needs to be detached from the frame - driver's side.
Here's where I feel there is a design flaw/problem... The square bracket has no provision to attach to the frame!!! So any rear impact strictly relies on the 2 bottom bolts on each side to take the hit... unless you drill holes in the frame to attach the square mount. Since I would rather not drill more holes.... I made some changes (temporary) and some recommendations to Expedition 1.
In the meanwhile, this is where the two spacers provided are supposed to go.
I went out and bought 2 Grade 5 5/8-11 bolts, 4 flat washers, 2 lock-washers and mounted the square Expedition 1 mount using this hole & access hole in the frame. Tighten them snugly so they can be tapped into position.
The bracket in place seen from inside the frame... Flat washers both sides.
Make both brackets flush with the top of the frame as shown here. Note the loose trailer/tow wiring on the driver's side - keep it tucked away as you slide the bumper on & off.
For reference - the large holes are the access holes to the 5/8" bolts holding the brackets to the bumper... If EXP-1 would relocate the back-up sensor holes to match these (29" center to center) - it could help with assembly?
Slide the bumper into place, put the spacers shown earlier between the tabs and the frame, snug them down. My recommendation is to pull the bumper all the way back, away from the body as far as possible... just in case something flexes it won't hit the body!! Also in case of impact... more room is better.
Adjust the bumper side to side aligning these edges with the body corners.
Close the rear door and check the bumper for being level with the body.
Check the "wings" for being level with the body line above.
Adjustments can be made by moving the square mounts up to level things out, or by bending the long tabs to change the angle of the wings.
I made no adjustments - this is a straight bolt-on, out of the box....
Since I moved the square brackets to line up with the holes in the frame, this is now how it lines up with the bumper itself. The bumper bracket still lines up with the inner holes so I chose to tighten the top bolt and pull the square bracket up against the bumper, then snug the lower bolt to determine the gap I will need a spacer for (not provided by Exp-1).
Even though I am only using 2 bolts to attach each side, feel that it is stronger because now it's bolted to the frame.
Note my recommended bumper changes.... Then it would use all 4 bolts, plus be attached to the frame. With the current design, the square bracket serves very little structural purpose...unless someone is pulling directly on the bumper with a clevis...
Once everything is aligned, tighten up the center bolts in the square bracket. I had to grip the end of the threads with some needle nose vise grips while turning with a wrench till I felt it was snug enough to stay in place while I removed the bumper.
Up to this point I had not installed the back-up sensors or the fog light kit - partly because the kit did not include mounting bolts :( and partly because I wanted everything fitted first. The Pilot fog light brackets were pretty flimsy :( Make sure that you install with enough clearance that any vibration wont cause the lenses to hit the bumper surround and crack them!!!
Next is trimming the OEM bumper skin - the installation instruction pix were horrible at best so I will provide some dimensions and multiple views of the places to cut...
As it sits now....
What ladder is that? Now I've got a swingout and the tiremount is gone, that ladder looks a lot better than the Gobi I currently have.
Re: Expedition One Rear Bumper Install on 08 FJC
I would be interested in Expedition One's comments on your install and suggestions.
I sent them an e-mail.... with pix.
The square bracket came with a center hole - it makes no sense to have it floating unless anyone can think of a reason.
Maybe the cheapest fix is to redesign the square bracket into a rectangle...
If they don't, I'll probly do that myself.
How many times are you going to post this?
I posted it once and submitted it to Steve for in the Tech articles... He ended up posting it here... I'm sure he'll combine/fix my mess...
No biggy - just tell us about the ladder :rocker:
Discussion Starter #9
I made that ladder after moving the spare up onto the ARB roof rack... Its still in process, adding a 2-Jerrycan holder onto it next. Its a pretty sturdy ladder, no new drilling required... We've used it a lot...
PM me if you want more info on the ladder... don't want to pollute the bumper install thread :)
I made a new thread for the ladder!
Looking forward to that.
The Laughing Member
Yep, my fault. :eek:
Hey Jerrit, where's the other posting of this write-up (other than the one in the Tech Articles)? I'll combine the two.
Discussion Starter #13
PM sent... you can probly just delete it...
Hmmm?? Interesting. i just installed mine 2 days ago. i followed E1 installation instruction. the bumper is really close to the body. don't notice any rubbing yet on the road, not sure about off road :bigthumb:. i will keep you guys updated what will happen after our trail run this saturday.
here's mine.
Had to customize my Bushwacker flares to hug the bumper.
By the way Gobi Ladder doesn't have the lower bracket anymore, also had to use a spacer to lift the ladder to keep it from hitting the bumper. spare tire mount had to be flipped for the rear door to closed with a 35" spare tire.:cheers:
Thanks for posting all the great info! I'm still on the fence....
Discussion Starter #16 (Edited)
01/17/10
Trimming of the OEM bumper.
Following are the pix detailing the cutting of the OEM bumper skin.
All pix are of the drivers side corner - lines are identical on both sides. Since each picture has all the info needed on it, I won't add many comments here, just the pix...
After cutting the ends of the center section, there is a corner that needs removed for clearance inside the Expedition One steel bumper.
I followed the lines on their install pix as best as I could - and added some dimensions to help everybody figure it out. Some additional trimming with a utility knife may be needed on install... Which I hope to do as soon as the rain stops...
Install of these corners, wiring the rear fogs & back-up sensors is all thats left at this point.
Here are the corners snapped back on. Some close-ups that show why the crazy cutting - so you have mounting points to hold them in place...
Wires for the back-up sensors have to come out the bottom of the bumper otherwise you can't reach the connector plug.
I backed my bumper away from the body as much as I could - just in case. As a result I probably could have cut less off the corners - but it doesn't matter.
right corner snapped on
mounting tab by tailgate
mounting tab underneath
snap at tailgate door (its somewhere...just not where i thought i left it)
This is how I ran the back-up sensor wiring under/through that brace...
Discussion Starter #18
Sorry... this is about 3 yrs later.. FJ in use lol..
The bumper needs re-aligned a little, its tilting down, a result of pulling stuff using the D ring shackles I believe.
When I remove my jerry can rack to repaint it I'll take some time to re-align the bumper.
Its been a great bumper so far!! No complaints.
How did you do the fog light wiring? I have been searching everywhere but can not find any forum that discusses the actual wiring install of the fog lights. Everyone talks about the physical positioning of the lights and then skips to the end pics. Also found instructions on wiring them on the front bumper, but nothing matches up with what is needed in the back. All I can think of is that it is so simple that no one needs to talk about it, but yet I can not be the only person unfamiliar with adding to the rear lighting electrical system. Please any insight & pics would be greatly appreciated! Thank you!
Share
1 - 20 of 25 Posts
