Don't know if they've done 5.7 swaps, I believe they may have, but they do understand the data differences from platform to platform and if you get the right tech on the phone, he may be able to at least point you in the right direction.
interesting read... but here's the thought I had a few days ago... the Lx450d or Lc200.. 4.5l twin turbo diesel Toyota motor.. stock its around 268hp, +479ftlb torque... 29mpg.(hwy). I've just started my research (have to source a motor to see its viability) power is cool.. but 870mile (more than double my current 410mile) range per (my 30gal) tank is (551 if u drain the stock 19gal) simply insane... I drive ALOT ...
(apologies my original conversion was off(now corrected).. the listed "combined" mpg is 24.759mpg) 2 independent tests actually gave a hwy measurement)
interesting read... but here's the thought I had a few days ago... the Lx450d or Lc200.. 4.5l twin turbo diesel Toyota motor.. stock its around 268hp, +479ftlb torque... 48mpg.(hwy). I've just started my research (have to source a motor to see its viability) power is cool.. but 1440mile range per (my 30gal) tank is (912 if u drain the stock 19gal) simply insane... I drive ALOT ...
Apologies my original conversion was off (based on the 2 Au independent tests 29mpg hwy or 8.0l/100km) I've since edited the result... factory "combined" mpg is listed at 24.759 mpg 9.5l/100km
Might need to relocate that decimal place too....
Factory figures are always ....a fit of fancy .... real world ...you would be lucky to get that.... even driving like granny may .... but its still worth investigating .... my only real concern is the switch to a diesel .... not really a comparison to compare diesel figures to petrol figures....
Cheers
Baz
:blueblob:
Cheers
Baz
Even that is wishful thinking.
Real world is probably closer to 12-13l/100km. Not a significant improvement over the 1GRFE. You'd be better off with long range tank(s) on the FJ and keeping the 1GRFE. If you want more power/torque, get the Raptor tune. These are infinitely more practical and significantly cheaper than a pie in the sky diesel swap.
I seriously don't get the US obsession with diesel. It sucks, it gels in low temperatures, it can't be stored because it suffers from mould & bacterial infections, it smells bad, and you can't get that stank out of your skin. It's better because the military uses diesel, right? Wrong on 2 counts - they don't use diesel at all - they use JP8 because it simplifies supply lines - one fuel for everything. OK so everything in Outback Australia is diesel, so it must be better? Nope - Same reason as the military, but with longer supply lines, so simpler is better. Yes, diesel will give a bit better economy overall in the real world, but it's really not worth doing a conversion.
The best fuel is the type that is readily available.
Yeah, although I wish I had better range, every time I price diesel versus equivalent gas vehicles, the extra purchase cost is too much to justify diesel, the payback isn't there for my needs.
And you're right, the one time I was behind a diesel vehicle on a trail I didn't like the stink. Although I will say the modern emission-controlled diesels stink a lot less than the older ones.
1st I already have the long range tank.. increased my range from 250miles to 400miles.
2nd I live in Florida so temp is a non issue.
3rd if diesel is so inefficient why are all semi's diesel torque, range, reliability..
I drive 750-1500miles a week for work. I love my fj I'd prefer to increase its range an reduce maintenance mobil1 swaps monthly are just a headache... every 2.5 months would be much easier... as per the Diesel toys link.. they claim a key turn swap at about 25mpg (vs my 14.87) is worth it not too mention a 10k interval for oil change an 500k service (just put a new motor in mine.. rear end being replaced as I type this)
understand the US "emissions" restrictions on Toyota, VW, Mercedes diesels are really just a way to keep Americans buying inefficient US built diesels..
Mercedes bluetec diesel S Class boasts 32.4mpg. Similar reports of the Audi Q7 tdi... Vw Golf Tdi 41mpg highway. Who'd buy a US diesel 18mpg average if a Euro/Jap that had double the range an twice the reliability.. were available in the states..
My uncle has a 1985 500sel turbo diesel.. still running strong... +450k miles...
MY bad, misread, thought the OP was going 'OT' (over the top?), so unconventional, exaggerated, or excessive as to be considered outrageous, unbelievable, ridiculous, etc.
Blown AA fuel motor > would be OT.
I've had LSA on the brain lately, rode in a '66 Caprice (3700lbs) with an LSA crate motor. Impressed.
Here you go: get a wrecked Lexus LX570/LC200 (with the 5.7L engine), an '07 or so, with some miles and body damage wouldn't be all that expensive. Its a boxed frame (like FJ) with all of the electronic systems in place. Pop the FJ body onto the LX570 frame, shorten the rear rails and figure out the fuel tank, supercharge the motor and use the LX gauges, wire harness and so on, and you'd be all set.
Tell us what you bought for your FJ for this Christmas. Ours is like part of the family, so we try to do something nice for it every year. What did you do or get?
This may sound weird but we are always doing something like 4x4, washing , a good coat of wax picture, a new sticker, wheels, lift, super charger or just an oil change the point is what you did today to or with the FJ cruiser.
This is my favorite thread on the jeep forum and probably the most...
I'm a bit perplexed by a squeaking/chirping noise that's coming from the vents when I run the heat and air. I took out the motor and fan to check for debris. When I remove the 3 screws, drop the fan and then run it, I'm not hearing the squeak. The air cabin filter is brand new. It makes me...
Hey Guys,
I just want to say how much I appreciate this forum. I have spent some time on some other forums recently (which I wont name) looking at trucks, and it occurred to me how fortunate we are here to have such a great community. The information which has been offered here over the years...
Guys and gals- I've had a persistent issue over the last few (3-4) years that has gotten much worse over the last 6 months. I've probably
My serpentine belt keeps shredding and the last 2 have lasted less than 2 months. I took this pic to illustrate that the belt seems to be moving back towards...
