1 - 2 of 2 Posts
Howdy I've owned my FJ for close too 2 years, I had a bad power steering pump and I've replaced it. The new pump didn't come with copper washers for the banjo bolt if someone could point me in the right direction of the correct size for the copper washers I would be internally grateful! Thank you so much!
I think that you are looking for the "horseshoe" shaped copper sealing washer that goes on both sides of the banjo bolt? It is 44327-30040 (all years, '07~'14). It is about $3.
By the way, I have read that if one is really in a bind, a copper sealing washer may be reused if it is first heated with a propane torch until it changes color. This re-tempers the copper so it can be crushed again. After the heating, you can air cool or water quench (unlike steel, copper won't care what the cooling rate is).
Norm
1 - 2 of 2 Posts
