Hello everyone, happy Friday!
When I have the time this weekend, I’m planning on installing some courtesy/puddle lights. It’s something that’s always bothered me to not have on the FJ.
I’ve searched quite a bit, and from what I can gather there is a wire that can be tapped into on a harness in the drivers kick panel area as well as one in the a-pillar which is what I’m leaning towards, the a-pillar one is described as the “middle” wire in a three wire bundle.
Unfortunately, the pictures of pretty much every post on this project are no longer available. I don’t mind electrical work but when splicing into existing wiring it’s nice to be sure it’s the correct wire.
Also, from what I understand it’s a ground trigger so I’ll have to tap into a constant on source in the fuse box and the “ground trigger” is what will actually activate the lights.
I’m hoping someone can chime in with some information on the wire to tap as well as ensure that I’m going about this correctly. Thanks!
