1 - 16 of 16 Posts
I have an 08 Trail Team FJ and the cruise paddle snapped off. I have the new module )($117.00 part at the dealer) and I don't know how to get to it. Did a pretty extensive search on the web and couldn't find anything. Any assistance would be appreciated.
Thanks, Karl
I'm sure this is mentioned in the threads Baz linked for you but as a reminder........
Un hook your battery
Accidental air bag deployment will ruin your day, and probably break yor nose
Wow, I've never heard of that happening on an FJ. Was it under normal circumstances or did a slip-up occur where the stalk was hit with some kind of considerable force?
That would be awful, and I hate it happened to you. Hope the install of the new one goes smooth and easy.
Yea they're dangerous. I am trying to decide if having one on the wheel is worth it at all. I'm okay with side curtains and all that but it seems like the wheel one deploys too easily and people get more injured from the bag in a minor wreck than the wreck.
Nope just disengaging the cruise. Of course I do have 190,000 miles on it and I use the cruise control several times a day. Also I am probably a little rough on the paddle. I slap it like I'm shifting a Nissan GT-R at Nuremberg.
Thanks for the links and I'll post how project cruise control stick goes.
They are dangerous when not moving and setting in front of it when working on something
I believe them to save lives in a front end crash
Since you can't turn it on while you have another car coming at you on the interstate at 70 miles an hour with only seconds to react, best to leave it hooked up and in place.
Reactions: Smoke1
I have only seen two steering wheel airbags deploy. One was a mid speed three sided flop that set all of the airbags off and a 50 mph dead center into a pecan tree. All were unharmed. Good luck with the toggle swap :cheers:
Reactions: Karlfly
Discussion Starter #13
Really you're THAT slow?
Point taken, it will probably stay hooked up.
Discussion Starter #14
THANKS A LOT for the help guys. That was REALLY easy. Disconnected the negative, took the blank covers off, loosened the torque screws, set the air bomb on top of the wheel and took the two Phillips screws off, unplugged the broken paddle switch and put the new one in. It took about 15 minutes and if I'd known what I was doing it would have taken 5. EASY stuff.
That makes me damn happy to hear. I am glad it wasn't a huge headache to replace. :cheers:
I just replaced my 2008 as well. No trauma, just broke during normal driving. I might have used mine a bit obsessively over the last 6 years. Wonder how much? I only have 58,000 miles. I didn't realize how much I used the cruise until it was broken.
BTW, if this ever happens to you, get a salvaged piece off Ebay. Mine was $45 and looks brand new.
1 - 16 of 16 Posts
