Here are a few pictures of the bracket I had made for my bypass filter. The OEM plastic battery tray fits inside the Aluminum bottom tray and locks the whole assembly to the fender. Fits 07 -09 and is much sturdier than the OEM plastic tray. The bypass filter fits on the left side using a floating 3 stud plate so the entire assembly can be easily removed. This tray will also fit the Amsoil bypass filter/bracket. The bracket is the result of a lot of planning, test fitting and refinement. It was designed to fit an Optima Red Top Battery. You can also delete the side bracket and use is as a beefed up battery tray.
