I wanted to get rid of my tool box I have bungied down in the rear cargo space...my wife has been on a Craigslist buying craze and I have to move it out of there every time we go on a new furniture adventure. I did a lot of searching on the forums, looked at all the different ways people have made a rear door rack and decided to add my own flare to it.
I was going to use the same metal I used in my other rear side rack project, however, after putting all the metal in my cart at Home Depot, I realized how heavy it all was going to be. Taking a cue from another members build, I started browsing the aluminum. I was instantly sold when I found 8' pieces of 1" wide x 1/4" thick (!!!) aluminum for $25. I bought two. All the steel I was going to use totaled about $50, so this worked out to be more efficient and MUCH lighter.
The only prob? I gotta drill holes in it now. Solution? My wife isn't the only Craigslist addict: found an estate sale, selling among other things, a bench top drill press (always wanted one!). I got it for $45 :cheers:
(despite the $50 price they so kindly wrote on in permanent marker
Total parts investment:
$50 - (2) 8' x 1" x 1/4" aluminum
$15 - various bolts, spacers and washers
Enough talk - picture time.
I came up with my own method of drilling my holes dead center. They are spaced 2" apart and I used a 1/4" drill bit.
I wanted the rack to be semi-modular. The long horizontal pieces (36" long) are two of the three sections that are actually secured to the door. The last section will be in the bottom space (about 34" long, if I recall), pictured at the end of this thread. The vertical pieces can be unscrewed and moved to the left and right. There will also be one short horizontal section that is movable up and down.
View from the back: large washers coupled with smaller washers.
