I have this problem when I go to start my fj the backlighting and radio along with the outside turn light flasher turn on and off. My fj will start it will do the same thing for a bit before turning off with no other light showing no check engine light no battery light runs good. Just changed the battery and the alternator. It all started to happen when I changed my water pump. After that everything stared to happen. Checked the voltage on the battery it was reading 12.7 volts after starting it was charging the battery at 13 Volts I can’t figure out this one out before start back dash lights flicker after start it dose it for a bit then goes away and at shut down everything’s flickers and goes away . Please help
