These ******** crack me up every time I watch it lol
These ******** crack me up every time I watch it lolAnd this guy will show you exactly how to do it... he can however, not tell you how to wash an FJ.
https://www.youtube.com/watch?v=ZN9nr7Pgg5g
I have a 2007 with the same 1/8 tank behavior. Been driving it for a while (years) with the issue with no other concerns from it I have discovered. Not sure if the newer models do anything more with that info from an ECU perspective, but I have no issues and just watch the ODO when I get down to that point.I have a 2012 FJ w/ 117k and just experienced this for the first time. Gas gauge hung up at right around 1/8 tank. No gas light. Engine stalled right as hit my ODO reading right when I would have expected it (I should have seen it coming!).
Filled up and the gas gauge now reads full. Will be interesting to see what happens as I drive through the tank of gas. Hard to tell from this thread if the problem repeats every time or is intermittent.
I am surprised that this appears to be a fuel level sender issue as I got accurate readings right up until it stuck at 1/8 tank. Seems like that would be more indicative of a float problem? For that reason I am hoping (probably foolishly) that somehow the gripe just goes away.
Previously someone asked if there was anything the float/sender assy affects other than the gas gauge itself? I.e. does the ECM use that information for anything? In other words, if one were to NOT fix the issue, and just deduce gas level via ODO and/or Ultragauge, will it damage anything?
Won’t heal itself ,unless you replace the float you just live with it ... you can drop the tank and replace the float or cut a hold under the back seat and access the tankI have a 2012 FJ w/ 117k and just experienced this for the first time. Gas gauge hung up at right around 1/8 tank. No gas light. Engine stalled right as hit my ODO reading right when I would have expected it (I should have seen it coming!).
Really the easier solution and gives you access At a later date for maintenanceMine just failed for the first time 110k miles. looks like i'm cuttin a hole.
Totally, there's no way i'm dropping the tank. :cowfrown:Really the easier solution and gives you access At a later date for maintenance
My mechanic said my fuel sensor was lying. After he repaired it I never had any other problems. Toyota cost$100 bucks and didn't have any idea what caused it.My FJ die on me driving home on the freeway from work yesterday. Turns out the fuel float was defective, and it ran out of gas with 1/4 tank reading on the gas gauge. Just lettin everyone know, hopefully a fluke, but who knows.
What's interesting is, I believe mine may have started reporting properly now, as I ran it low the other day and the fuel light did come on, etc (before it would run out of gas before it got to that point). I'm a bit gun shy to run it that low again knowing the gauge had been off by at least 1/8 tank to 100% confirm it, but it does seem to be reading more accurately now, so not sure what is going on... very strange. Bottom line though is I'll never push it over 300 miles on a tank just to be safe.Won’t heal itself ,unless you replace the float you just live with it ... you can drop the tank and replace the float or cut a hold under the back seat and access the tank
My 2007 FJ just did exactly this...The gauge read 1/8 tank and it completely stopped mid road. AAA brought a gallon and we were all good. I have about 120,000 miles. Would appreciate solution ideasRe: Defective Fuel Float
My FJ did the same thing last night. Driving down the street, running fine and just stalls.turns over wont start.Gauge read I Had an 8th tank of gas left.No low fuel light, I ran with less gas before with no problems.I have about 3,000 miles on it.Had it towed to the dealer where they told me it was out of gas and needed a new sensor.They had to order it and it would be in next week and that I should keep at least 4th of a tank of gas until they fix it.They also told me Toyota is keeping close tabs on problems with the FJ.
you have two choices replace the sending/float unit or keep gas in itMy 2007 FJ just did exactly this...The gauge read 1/8 tank and it completely stopped mid road. AAA brought a gallon and we were all good. I have about 120,000 miles. Would appreciate solution ideasKaty
