1 - 9 of 9 Posts
Check out what just came in stock here ToyTec Lifts!!
The new ICON Delta Joint Retrofit Kits and full control arms for the 07+ FJ Cruisers!!!
Full UCA: 58451DJ - ICON Delta Joint Tubular Upper Control Arm Kit
614551 - ICON Delta Joint Retrofit Kit - 07-14 FJ Cruiser/03+4Runner/08+Land Cruiser
We also have the tool in stock to swap out the traditional Uniball in the Icon Arms.
614519 - ICON Delta Joint Install Press Adapter Tube
*** If you have the Billet uppers the tool will be different.
KEY FEATURES:
Patent pending Delta Joint combines the durability of a ball joint with the performance characteristics of a traditional uniball
Sealed design and zinc plated housing protects Delta Joint from the elements, road salts, and other debris
Metal on metal internals and a greasable design for maximum longevity and noise-free operation
Capable of high angularity required for lifted applications
Carburized taper pin provides increased corrosion resistance, decreased internal friction, and less chance of thread galling on assembly
Pullout strength greater than comparable industry standard uniball
Application specific taper pins for precise fit across a wide range of vehicles
5 Year ICON Limited Warranty (When used with ICON Vehicle Dynamics suspension components, visit Delta Joint | Icon Vehicle Dynamics - for more info)
Let me know if you have any questions!!!
-David
I'm sure they come with a little bit of grease pre-packed in the Delta Joint, but it is always a good idea to double check them after install. They do come with a greaseable zerk on the joint.
-David
What’s the part#’s for those of us with the billet aluminum UCA’s?
1 - 9 of 9 Posts
