1 - 13 of 13 Posts
Sorry in advance, but what's the Difference between a lift kit or body lift?
If you can also post pictures to show the difference that would be awesome!!
A body lift is just that, lifts the body a little higher or to level if from the frame.
A full lift kit lifts everything in suspension to provide more ground clearance and suspension travel.
A body lift will allow bigger tires so may provide a 1" or 2 more ground clearance but will not change suspension travel.
fka RockWeasel
I guess this is what you are asking about, but most folks won't recommend it --
Revtek
It's always better to save up for a true 3" suspension lift, like an OME kit. Or level the front with OME 883 springs for $170 until you can afford the full lift.
Then again, if it is just about economics and you are doing it for appearance, you probably could get away with the Revtek.
I drove on Bilsteins and the OME 883 springs up front to level it with the rear -- and it was fine. Even had 285's stuffed in without any rubbing.
I mean, I think the Revtek 3" lift runs $400+. Save up another $400 and you could have the real OME 3" lift with new shocks and springs.
Worth it in IMO.
If you do a body lift, remember, the body is the only thing that's lifted. I know it sounds obvious, but you're going to have a bigger gap between the frame and the body. The bumpers and anything else mounted to the frame stays put. You'll have to live with the gap or find a solution to hiding it.
Discussion Starter #12
I guess I'd really like to see some close up pictures of what you mean.
But with the body lift, the truck will look higher right?
the body lift gap, witha 1 1/4" body lift, is nothing to wine about or have to "deal with". its really nota big deal. feel free to chk out my build..ive got the body lift ontop of a suspension lift, and have no issues! no gripes! no nada...
1 - 13 of 13 Posts
