1 - 7 of 7 Posts
4-Corners Moderator
Used the JULY4 discount code to order me some much needed dome lights for the main dome light and cargo light of my 2008 FJ. I ended up getting your "cool white" LEDs in the SMD12 Board version. They are sure an improvement! Thanks Diode Dynamics!
Stock Bulbs
SMD12 LED vs Stock
Cool White SMD12 Board Installed
Is it plug and play? Are they easy to install?
I want dome light
Cargo light
License plate light
Reverse light
I dont want the turn signal as the resistor stuff confuses me
I wish diode just had an “interior led” package.
Do they still do free shipping?
answer to first two of your questions is yes
third question: check with the seller (there are any number of sources for LEDs for dome lights, as they all work the same way)
Desert Moderator
I want dome light
Cargo light
License plate light
Reverse light
Do the turn signals and reverse lights. Add the Smart Tap flasher module https://www.diodedynamics.com/smarttap-cf18-led-flasher-module.html
and you won't have to worry about hyperflash.
The Smart tap module is great - some great hazard flasher sequences, and just tap the turn signal stalk and it flashes 3 or 4 times (or more or less - configurable by you) and it adds courtesy light functionality. It's plug & play. I have one and it's brilliant.
1 - 7 of 7 Posts
