1 - 20 of 79 Posts
Vendor
SmartTap CF18 (LM449) Flasher Relay
Designed and Manufactured in St. Louis, Missouri!
The SmartTap™ is a replacement turn signal flasher module compatible with any vehicle using a CF18 (LM449) Flasher, including the Toyota FJ Cruiser. Programming each mode is simple with the help of the included programming guide and the use of existing vehicle controls.
Tap-to-Signal: One-touch signaling is a convenient way to signal to other drivers when switching lanes. Simply tap the turn signal for a series of signal blinks.
Arrival and Departure Modes: When the lock or unlock button is pressed, the surrounding area will illuminate for better visibility when approaching or leaving the vehicle at night. The lighting time can be adjusted from 10-90 seconds for additional illumination, or disabled if desired.
Unique Hazard Functions: The SmartTap™ has built-in strobe, slo-mo and wig-wag hazard functions to help the vehicle stand out when the hazards are on. Apply these functions on their own, together or with the strobe setting for a total of EIGHT unique hazard functions!
This product was designed and fully manufactured by Diode Dynamics, in St. Louis, Missouri. It is fully made in USA.
Diode Dynamics: SmartTap CF18 (LM449) Flasher Relay for Toyota FJ Cruiser
All products by Diode Dynamics are backed by a 30-day satisfaction guarantee and a three-year limited warranty.​
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Wig-Wag Strobe Function!
Absolutely great setup guys! Installed mine this evening, took around 20 min. Worked ok with the OE bulbs, but the LEDs really make the strobes pop. I also love that it can be converted back to stock just as fast.
Vendor
The Wig-Wag strobe is probably my favorite feature, especially with the instant on-off with LED as you mentioned
Thank you for your support!~
Nick C.
Vendor
Discussion Starter #12
I upgraded to Diode Dynamics both of my rear & front turn signals with the CF18 (LM449) replacing my OEM flasher. This was I think a few weeks before the release of SmartTap. If I get the SmartTap, I will again replace my CF18 flasher I have now, correct?
The SmartTap is a new replacement flasher. It will indeed replace the unit you've previously purchased.
Give our team a call, we'd be happy to assist you with an exchange: (314) 205-3033
Thanks!
Nick C.
It's worth it. Pretty cool feature. I just installed it in a customers FJ.
Sent from my SM-N900P using Tapatalk
I have tapturn for my 2015 forester.
I was hesitating if I want to spend ~$100 get it shipped from canada.
This one is packed with more features and cheaper.
definitely in my want list now.
1 - 20 of 79 Posts
