How many qts of ATF did you actually have to use?First off I want to thank bartt your parts list for this job and instructions were spot on Hoses fit snug and didn`t need clamps or anything. This job is a easy as changing your oil. Here are a few pictures to see what I did
Hope this helps this job is as easy as it gets
I ran 14qts through before it looked bright red and then 1 more just incase. I have 1 unopened qt. I plan on returning since its $7.50 a qt.How many qts of ATF did you actually have to use?
DEWFPO
Thanks for the info.I ran 14qts through before it looked bright red and then 1 more just incase. I have 1 unopened qt. I plan on returning since its $7.50 a qt.
Bartt thank you for making this job sound as simple as it is. I have heard so many horror stories about this that I almost didn`t do it. Then I read your post and you made it sound easy which it is. Your parts list and how to is top notch. Feel free to move the pics to the how to section or just leave them here. Thanks again SteveSanderhawk - glad you posted the photos, that really makes it clear.
That would not be a good idea. Using a non-Toyota tranny fluid would be roughly equi valent to getting a blood transfusion with the wrong blood type. The WS fluid used in our trannies is a lower viscosity than the other mass-market fluids. If you want firmer shifts, get a replacement valve body or see if the tuning devices can alter shift line pressure.
These guys ( IPT Performance Transmissions Torque Converters and Transmission Parts for Ford, GM, Chrysler, and Import vehicles make a valve body kit for the 5AT's in the FJ that will give you quicker, firmer shifts. DEWFPO
Kinematic Viscosity is only 1 characteristic of an ATF. Fluids are spec'd to match compatibility with the clutch pack materials, torque convertor ratios, operating conditions and pressures. I realize on paper the DexVI specs look somewhat similar to other ATF's but chemically they may be very different. That transmission runs about $6,500 new. Why would you risk that to save <$100?And for all you Low Kinematic Viscosity people, Toyota WS is rated at 6 cSt, Dexron VI is rated at 6cSt, Amsoil Low Visc Dexron VI is rated at 6 cSt, so running this fluid is the correct viscosity.
Heres the parts list 16 qts. of toyota ATF WS trans fluid.
3/8 ID clear hose hooked to the lower trans hose nipple coming out of the radiator
Same hose running out of the bottom of the truck into bottle measure the fluid coming out
1/2 ID clear tube taped to funnel and zipped tied to stay there while filling
same hose shoved in the fill plug about an inch
What the fluid looked like compared to new
I changed the Trans fluid right at 50,000 miles I figured with the all the offroading I do it wouldn`t hurt. any mechanical machinery needs to maintenced no matter what it is. I couldn`t believe toyota said they don`t change it. How do they know how long my FJ is going to last.Thanks for the pics! Someone in this thread said toyota does not recommend a tranny flush, saying it should be good for the life of the vehicle, I dont believe it for a second especially seeing how dirty your old fluid is. How many miles did you have on your rig at time of flush?? Thanks again
Bartt, thanks for the great info!!!
That's news to me. I guess I don't frequent the Tundra/4Runner sites so I didn't know about this. I haven't looked at a bottle of DexVI in a while. Some of us are under the impression that the Toyoya type WS is a full synthetic, I thought the DEX Vi was a semi-synthetic. Any thoughts on that? :cheers:There are hundreds of posts from other Toyota Tundra/4Runner users who have used Dexron VI without issue. I could not find a single post where someone said Dexron VI made their Toyota transmission go south. The Dexron VI packaging specifically states its recommended for use where Toyota WS is called for. To each his own.
