Items needed:
1 1/2" pipe clamps (3) got mine from McCoy's $5ea
Fender washers (3)
Wing nuts (3)
Note, it can be done with 2 of each but I'd recommend replacing the bolts with grade 8. Grade 8 bolts can also be used for 3 mounts as well. But I used provided hardware for mine.
Pipe clamps come as shown...
Remove the nut and bolt and paint with spray-on bed liner.
Select your mounting position on your rack and wrap with electrical tape for traction. Then mount clamps loosely using the nut provided.
Hold up jack and space out the mounts to match the holes.
Once happy, tighten down the nuts.
Mount Hi-lift and use the fender washers and wing nuts. If not using grade 8 bolts... Don't over tighten. Fender washers should bend in a little.
Lock with a handgun lock... The one with the flexible cable.
You're done.
Check tightness daily until you are comfortable with the mounts.
I've tested mine for a few months now without a problem. I'm not saying it's perfect, but it works so far. I apologize in advance if someone beat me to this.
Enjoy!:rocker:
Fender washers (3)
Wing nuts (3)
You're done.
Enjoy!:rocker:
