How do you navigate to those?Huh? there is a dimmer already for screen, lighting and (2) output switches are on off mom or no/off/on
BUMPHow do you navigate to those?
Brightness there are a few ways, but best to hit source twice and choose settings.BUMP
No really, how?
Thanks Sav. I found the brightness slide switch. Still checking on how to set it to the clock to determine whether a dimmer is worth it.Brightness there are a few ways, but best to hit source twice and choose settings.
Screen set up (look for small arrows along top as there are more than one page of options at times) you can lock the brightness or set it your self, it auto dims via clock settings and location etc..
switch menu should be on second page and you can change name of switches etc..
try touching screen at any time along top or bottom middle there are shortcut "zones" to get to these menus as well.
in map view you can drag your finger along small bar at bottom left to zoom in and out of map....dvd playback you can forward chapters by touching left or right, controls are along top or bottom as well...
locks on its own. you can lock at a setting too. dont forget to go to the bottom choice and save your settings.Thanks Sav. I found the brightness slide switch. Still checking on how to set it to the clock to determine whether a dimmer is worth it.
Thanks again.
