1 - 15 of 15 Posts
I had these on a Z71 Avalanche. They have the same bolt pattern(6x139.7).
I tried them on my 4x4 FJ but, the hub sticks out and the holes in the center of these wheels are too small.
Do the hubs stick out on the 4x2? If so, does it need a large hole like the 4x4?
I would guess that no the hub centers dont stick out on the 4X2's ( I have a 4x4) but the studs are most likely the same due to production costs you know use as many of the same parts on both trucks
what's the bolt pattern?
i believe chevy center bore is different from the fj center bore so will not work even if same bolt pattern
I think you're right
Correction: If you put a Chevy part on a Toyota, you increase the share value for Chevy.
they were made for a chevy fit.... plain and simple ;)
Discussion Starter · #12 ·
I think they would look good on a 4x2.
1 - 15 of 15 Posts
